what is this wire to?
Old Apr 24, 2018 | 06:41 PM
The Big Hat's Avatar
Car: 89 RS
Engine: 5.7 T.B.I.
I'm referring to the one with the fat connector running over the blower motor. I found it today when looking for a reason why my fan doesn't blow as fast as it should the other picture shows the end of the wire that was just dangling in the corner behind the blower motor.
Attached Thumbnails what is this wire to?-img_20180424_182801.jpg   what is this wire to?-img_20180424_182813.jpg
Old Apr 24, 2018 | 06:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: what is this wire to?
First pic looks like Underhood light
Old Apr 24, 2018 | 06:50 PM
Car: 89 RS
Engine: 5.7 T.B.I.
OH! ok! that makes sense I have a fiberglass hood. Thank you very much!
Old Apr 24, 2018 | 06:52 PM
Car: 89 RS
Engine: 5.7 T.B.I.
the other pic is the other end of the wire
I was on a thread that said there was a connector that got burned up on a red wire that ran across the firewall. That is what I really wanted to check on. All my fan speeds run but high is not as fast as it should be.
Drew's Avatar
Both are actually. The black connector is sometimes used closer to the light assembly.
The factory "SMC" fiberglass Z28 hoods used in 82-83 use a different light assembly. Instead of grounding through the hood, they have a ground wire that follows the power wire back down the hood hinge.
Old Apr 24, 2018 | 07:07 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
My fans high speed also doesn't run as high as it should.
Old Apr 24, 2018 | 07:11 PM
Engine: Lb9
Transmission: M20
The fan might be old. High is direct 12v without going through the resistors.
It does get controlled bye the fan relay.
Old Apr 26, 2018 | 08:21 PM
Car: 89 RS
Engine: 5.7 T.B.I.
I had a mechanic argue with me today about this claiming that high still went through a resistor but it's all over that no it's a straight 12v connection. I have had the fan replaced. Is it possible that I have the wrong fan?
Old Apr 26, 2018 | 08:49 PM
Engine: Lb9
Transmission: M20
You can check voltage before and after the relay.
mr420joe
Oct 12, 2009 10:18 PM
iggy1991
Feb 27, 2005 12:39 AM
Hummer
Car Audio
Jun 6, 2001 05:37 PM
Todd 92 Z
Car Audio
Jan 30, 2001 04:14 AM
