Relocating Turn Signals
Old Apr 24, 2018 | 06:55 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
I know this is a touchy subject here, but here goes. My TA is a Knight Rider Replica. The nose I'm using doesn't allow the stock front turn signal lens. I have some aftermarket non LED turn signals. I've tried wiring them up and the parking lights work as they should and the 4 way flashers work as they should. However when I just turn on the right turn signal it doesn't work. I'm planning on placing these down in the nose next to my fog lights. Any ideas on why the blinker isn't working? Again these are not LED lights.
Thanks guys
Old Apr 24, 2018 | 08:27 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Relocating Turn Signals
Check your Grounds.
Personally, I wouldn't run park lamps. You don't need 'em, and you already have side marker lights.
I would conneect the blue wires (turn signals) and leave the brown wires disconnected. If they don't work, you may need a new flasher...
Old Apr 24, 2018 | 08:55 PM
Car: !982 Trans Am
Axle/Gears: 3.08
Thanks for the reply. The sockets that were attached to it that went into the factory lens works. If I wire it back on the car it works. I've even ran a jumper from the new light to the ground on the battery just to test that. The only thing I haven't tried is cutting the socket off the the other side and attaching the other aftermarket so they match but I don't see how that is going to make a difference.
Old Apr 29, 2018 | 08:38 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I have the same problem. Works fine with the factory bulb but with LEDs wired in the circuit comes on but won't blink. I wired red and black to the running light two led strips, and yellow and black to turn signal s also two led strips. Running light strips come on work fine, Turn signal strips come on but don't blink.
Old May 1, 2018 | 06:54 AM
T.L.'s Avatar
You need a flasher that is compatible with LEDs..
di11on
Nov 28, 2014 09:16 PM
Firebat
Apr 25, 2008 11:03 AM
doc_honda
Aug 22, 2006 09:18 PM
cjmelendez
Jan 10, 2006 09:34 PM
John89IrocZ
Jan 19, 2001 11:25 PM
