Airbag scan tool
Old May 1, 2018 | 07:25 PM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Airbag scan tool
The Infl Rest light is on solid in my 27K mile 1990 IROC.
Looking for information on how to diagnose the problem.
Searching the web and this site,I'm not finding much.
Any idea on were to get the elusive scan tool
Old May 1, 2018 | 08:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Airbag scan tool
You might need a tech 1 to communicate with the derm or even a mt2500 might have the capability.
Old May 2, 2018 | 08:55 PM
BigBlock73's Avatar
Engine: 5.7
I keep searching and not coming up with much
I found this on a Corvette forum from 10 years ago
https://www.corvetteforum.com/forums...amp-reset.html
I also found some stuff talking about the "clock spring" as being a usual problem but couldn't find if 1990 had it
I know this is the first year of the airbag in a Camaro and probably most cars.
Can you explain why this feels like such Taboo.
I'm putting this car on the road after 14 years and would like to get everything working again.
Old May 2, 2018 | 09:06 PM
Engine: Lb9
Transmission: M20
Have you tried grounding pin k in the aldl or is there a wire in pin k ?
http://www.answers.com/Q/How_do_I_re..._1990_Corvette
http://www.austinthirdgen.org/mkport...traint_AJ3.jpg
Old May 2, 2018 | 09:12 PM
BigBlock73's Avatar
Engine: 5.7
I have not
This is the method to clear correct?
Old May 2, 2018 | 09:18 PM
Engine: Lb9
Transmission: M20
I would assume so. It I don’t have a fsm for your car.
http://www.corvetteactioncenter.com/...t-sir-160.html
Here’s a good thread to read
https://www.thirdgen.org/forums/elec...ight-91-a.html
https://www.autozone.com/repairguide...96b43f803867cf
Old May 3, 2018 | 12:01 PM
BigBlock73's Avatar
Engine: 5.7
I’m going to have to come up to speed on the lingo.
I’ve been working on my 73 for the last 10 years getting it to the point of being able to drive it. Now it’s time to bring the 90 back to all its glory.
I’m sure I’ll be having many more questions and glad to have this site for the knowledge it brings.
Thank you
Old May 3, 2018 | 12:10 PM
BigBlock73's Avatar
Engine: 5.7
Old May 13, 2018 | 06:33 AM
BigBlock73's Avatar
Engine: 5.7
I got some time
Tried to clear codes but wouldn't work
Checked for codes
Got code 24
Steering column voltage to low
I have the service manual and it warns about what kind of volt meter to use.
Can I use my standard volt meter to check for issues,don't want to deploy the airbag ??
Old May 13, 2018 | 06:41 AM
BigBlock73's Avatar
Engine: 5.7
24 Steering Column (Clockspring or Detonator) Voltage (12 volt VSS) Too Low
Old May 13, 2018 | 04:12 PM
BigBlock73's Avatar
Engine: 5.7
Will be pulling the steering wheel off to check the Clockspring.
Been searching for a replacement and haven't come across anything.
Any ideas?
Old May 14, 2018 | 11:45 AM
Engine: Lb9
Transmission: M20
Post a ad in the wanted classifieds or look on eBay.
Hope you find the issue without to much hassle.
Here is a car being parted out
https://www.thirdgen.org/forums/inte...amaro-z28.html
Old May 15, 2018 | 05:43 AM
BigBlock73's Avatar
Engine: 5.7
Pulled the steering wheel and checked the clock spring.
It had good continuity.
That would have been too easy.
Service manual says to start checking all the wiring for damaged or broken wires.
Way to much disassembly involved to test all the wiring.Car has never been in a accident and interior wiring hasn't been touched.
Pulled the bulb since I was partially in to the dash already.
Will deal with this issue when I have much more time as this repair is going to be very time consuming.
ml258-89iroc
May 6, 2003 08:31 AM
ragtopcamaro
Feb 25, 2003 06:35 PM
Ukraine Train
Jan 28, 2002 01:26 AM
Bandit76
Jan 8, 2001 12:07 AM
