can't get key out of ignition and it will not start.
Old May 19, 2018 | 10:35 PM
DRhodes's Avatar
Car: 1969 Pontiac Firebird
Engine: 350 cu. in. 4 bbl
Transmission: Turbo Hydra-Matic (M40)
1969 Pontiac Firebird with console shifter. had transmission in reverse and wheels were spinning. put shifter back in park then turned off the engine. key would not go into lock position and now the engine will not start. just getting generator light. do you think its the lock cylinder needs replacing or maybe shifter is not going into park?
Old May 20, 2018 | 08:44 AM
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
Re: can't get key out of ignition and it will not start.
Are you saying it is an 89' or 69'?
On an 89' it sounds like the shifter is not fully in park,try putting the shifter in neutral and see if the engine will start.
Old May 20, 2018 | 09:00 AM
DRhodes's Avatar
It's a '69. I tried that but it still won't start.
Old May 20, 2018 | 09:07 AM
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
Is the key in the dash or steering column?
Old May 20, 2018 | 09:35 AM
DRhodes's Avatar
Key is in the steering column. It has the cylinder key lock.
Old May 20, 2018 | 10:05 AM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
I know my 69 Chevelle has the steering column section rotate by shifter linkage to lock ... but mine is a 4 speed. Something to check. Google Team Camaro, that forum will help if you don't get it figured out.
Old May 20, 2018 | 10:20 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Try grabbing the bowl (fat ring) piece of the steering column just below the section where the key cylinder is located. If the bowl is turned counterclockwise, the key should come out. Many GM cars of the era used steel rod linkage going from the shift arm, up the firewall to the column. Bushings, wear, or adjustment may need addressed.
Old Jun 13, 2018 | 04:35 PM
DRhodes's Avatar
Thank you jmd. I turned the ring like you said and the key came out. It should start now. Thanks a million!
jonny_sanchez99
Mar 16, 2018 08:54 AM
charliemccraney
Mar 7, 2018 07:19 PM
elektrik
Jan 30, 2018 09:51 PM
Gangsta Stude
Sep 26, 2016 12:23 PM
Joshua Leslie
Nov 25, 2002 05:10 PM
