turn it
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: turn it
check the fuse panel with a test light. one side of the turn signal fuse should have power. If not then open the "convenience center" and see if the flasher unit is alive.
do your hazard lights work?
If they do, its more than likely the flasher unit. there are 2 of them
The turn signal flasher flashes faster than the hazard lights.
The hazard flasher flashes slower to increase the time they can last on the battery.
if the hazard one works, pull the flasher and plug it into the spot where the turn signal flasher is. if it flashes, then your old flasher is dead, head down to whatever store they have in the states and pick one up for 10 bucks.
see how you go.
see how you go.
berlinettakid
Feb 8, 2005 03:05 PM
EJs90IROC
Oct 17, 2000 09:30 AM
