Fans kick in when jumping ALDL terminals
Old May 31, 2018 | 12:50 PM
FinnZ28's Avatar
Car: '86 Z28
Engine: 305 TPI (LB9)
Transmission: TH700R4
Axle/Gears: 10 bolt/2.73
I'm in the process of sorting out the wiring in our '86 305 TPI Camaro. So far it's been going pretty good, and I'm glad to have found out that the harness hasn't been chopped up as bad as it could be. There were a couple of wires that had some questionable splicing done to them. After removing those, the fuel pump and power windows started to work properly.
Anyway, I was going through the process of setting the minimum idle speed, following the instructions found on here and a question popped up. As I jumped the A and B terminals in the ALDL connector and turned the ignition on, my fan(s) sprang to life. Is that normal, or do I have some funky wiring goin on in there too?
Old May 31, 2018 | 03:17 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: Fans kick in when jumping ALDL terminals
Nope that what it supposed to do
Old May 31, 2018 | 03:18 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Yep, perfectly normal, though the first time I started working on this stuff, it startled me, too.
Old May 31, 2018 | 09:38 PM
FinnZ28's Avatar
Car: '86 Z28
Ok great, thanks for the answers!
Steveh4263
Aug 24, 2014 12:20 AM
bmfIROC-Z
Aug 17, 2007 02:27 PM
85f-bird
Aug 10, 2004 06:42 PM
IROCketZ28
Mar 4, 2001 12:28 PM
