steering column change, no start
Old Jun 19, 2018 | 12:51 PM
89FoRMulaz's Avatar
Car: 1989 Firebird Formula
Engine: 5.0
89' Firebird -
So i had a very bad steering column and i changed it but now with the vats system i cant get it to start (i'm guessing). i am getting it to crank but no spark or fuel.
I don't have my old steering column anymore so i cant rob parts from that. i have seen the painless box you can buy but i'm not sure on where it goes or if that's what i really need.
Any help would be very appreciated!
Thank you
Old Jun 19, 2018 | 12:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: steering column change, no start
The loss of spark is unrelated to vats. You might have a bad ignition switch. Or misadjusted switch. The pink wire at your ignition coil gets power with the Leo on, cranking and running. The loss of injector pulse could be vats but you need to get spark/ power to the ignition system first.
Old Jun 19, 2018 | 12:59 PM
89FoRMulaz's Avatar
Engine: 5.0
thank you! i'll look into the ignition switch
Old Jun 19, 2018 | 01:02 PM
Engine: Lb9
Transmission: M20
I can’t find a good schematic on the power to the ignition coil. It does pass through the body connector c100 by the master cylinder . Pin f4
http://www.austinthirdgen.org/mkport..._1989_C100.gif
Old Jun 19, 2018 | 01:07 PM
89FoRMulaz's Avatar
Engine: 5.0
Ill look into this too. Thanks again
Old Jun 19, 2018 | 01:08 PM
Engine: Lb9
Transmission: M20
Post 2 has a schematic
https://www.thirdgen.org/forums/elec...l#&gid=1&pid=1
Old Jun 19, 2018 | 01:11 PM
89FoRMulaz's Avatar
Engine: 5.0
I'll go from here and check back in later!
Old Jun 19, 2018 | 01:39 PM
Engine: Lb9
Transmission: M20
This might be the same hope it helps to diagnose
Old Jun 19, 2018 | 02:23 PM
89FoRMulaz's Avatar
Engine: 5.0
Thank you!
I really hope I can get my car running again!
Camaro kid97
Sep 18, 2014 01:18 PM
SLAYER6669
Jul 31, 2005 10:29 PM
SLAYER6669
Jul 24, 2005 04:16 AM
