No crank/no start 88 firebird
Old Jul 1, 2018 | 07:44 PM
82transm's Avatar
I have a no crank condition with my 88 firebird, 350 swapped. I have power on the big wire (battery to starter). I have continuity between the purple wire that goes to the small terminal of the starter and the thick yellow wire on top of the steering column connector (which I understand is the start wire) This is with the key in the start position.
However, I have no voltage going to the purple wire on the starter when the key is in the start position.
Can anyone confirm from this info that it is a wiring vs starter issue?
​​​​​ thanks
Old Jul 1, 2018 | 08:34 PM
PaulyC's Avatar
Re: No crank/no start 88 firebird
Check your neutral safety switch, needs to be in park or neutral or the switch could be bad. Other than that you should see a red wire at the ignition switch, that should have 12v all the time. If not, you have a fusible link either blown or not connected correctly.
Dom Scarpellino
Dec 18, 2017 08:51 PM
thunderstick
Sep 16, 2013 04:56 PM
rbrooks
Mar 3, 2010 11:50 PM
Superblue87Formula
Aftermarket Product Review
Apr 25, 2001 02:39 PM
