where can I get a forged 350 crank (3.48 stroke, 3.75 rod) crank for 1-piece seal
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Well, for one thing, the rods are 5.7" in length stock, but you can use 6.0" rods with pistons designed for 6.0" rods. http://www.scatcrankshafts.com sells GOOD 9000 series cranks for your application. You really don't need a FORGED CRANKS, if you really want a FORGED CRANK, LUNATI, and many others sell them. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
GM also makes one. Part # 14096036 sells for around $500 and is a forged steel crank, 3.48" stroke, 1-piece rear main.
Jason
[This message has been edited by 89BlwnRs (edited April 25, 2001).]
Jason
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
