Strange brake light issue
I have a 86 Trans Am and just noticed that the right brake light and right rear turn signal are out ONLY when the headlights are on. I replaced the bulbs as at first I did not realize they worked without the headlights on. The left brake light and turn signal work ok. I just noticed this before heading back to college for finish the summer term, so I have not begun to look at wiring. I hope that someone had a similar issue and could give me a head start on the problem. Thanks.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cigars, Cigarettes, Brakelights
Does your car have a digital dash?
Till you answer the above, check all bulbs to make sure they are NOT LEDs, and installed correctly.
A common mistake is people installing 2 filament bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
Happy Racing !
I Dont Mind Wreckin On The Track, No Paperwork To Fill Out
Happy Racing !
Transmission: 765R4
Brake Dance
1►Did you recently buy the car?
2►Have you ever seen these lights working correctly on this car?
Happy Racing !
Rule Number 1 Is To Know Which Rules You Can Break
Happy Racing !
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Strange brake light issue
having the wrong bulb in the turn signal can do it as well make sure you have 1156 bulbs and check the grounds.
Just replaced the left most socket, 2 wires, on the right side. It had a small crack that allowed the bulb to move a bit. That appears to have taken care of the issue. Thanks for all of your replies.
DirtDawg57
Jul 10, 2010 08:28 AM
Scooby Doo
Convertibles
Dec 15, 2009 05:20 PM
IROCJoyce
May 15, 2008 11:11 AM
