ALDL wiring help
Old Jul 21, 2018 | 06:43 PM
bowtied_gta's Avatar
ALDL wiring help
Gentlemen! My ALDL connector is gone! Background- car (90 formula) was originally tbi, then it was carbeurated, now I’ve put a tpi setup on it with an uncut engine harness from hawks. Car runs as of today. Issue is someone cut the ALDL connector out when they carbeurated it, why I have no idea. I never noticed it until I needed to ground the pins and reset my tps/iac (once I bring the car off an idle it won’t come back down).
There’s a few 18 gauge wires capped off under the dash. I need to pin them back into an ALDL connector. Does anyone have schematics for this? I’ve found ALDL pinouts on the site but they aren’t color coded with the wires. I need to know what wires go to which pins and where they terminate elsewhere in the car (ecm harness I’m assuming). Thanks!
edit- found a diagram for a 730 ecm that shows colors on a thread from someone making interface harnesses for a mega squirt stand alone system. All set!
evilstuie
May 21, 2009 04:33 PM
IroczInOz
Oct 23, 2006 10:19 AM
Mike89GTA
Mar 14, 2004 02:41 PM
jamesbob02
Aug 9, 2003 12:31 AM
Christos
Nov 16, 2001 06:47 PM
