1991 Camaro RS tach issues
Old Aug 24, 2018 | 12:54 AM
garrett3698's Avatar
Car: 1991 Camaro RS
Engine: LS6
Axle/Gears: Stock axles, 3.73 gears
So I like many had the issue where my tach wouldn’t read properly, didn’t really work at all to be honest, so I ordered an after market board, one designed better than the OEM ones and unfortunately my problem is still there. I’m starting the wonder of the issue isn’t actually the tach, but something else, I’m no sure where to start looking though so if anyone has any ideas on where to start looking, they would be greatly appreciated.
My tach typically doesn’t move off of 2000rpm, but every now and then when I’m driving it will jump past redline when I’m cruising at normal rpms (1500-2000rpm).
My car is a 1991 RS with a 400sbc, tbi, 5 speed t5.
Old Aug 24, 2018 | 06:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 Camaro RS tach issues
You could see if member Greg could test your tach.
https://www.thirdgen.org/forums/engi...achometer.html
Kitten Tooth
Dec 31, 2016 04:27 PM
Badas.sbird
Sep 15, 2007 12:21 PM
86TpiTransAm
Apr 24, 2001 11:55 AM
Duffster
Oct 16, 2000 09:08 AM
