Headlights suddenly pop up with Parking lights
Old Aug 24, 2018 | 10:40 PM
Biggyniner's Avatar
Hey guys,
So forever the car would just turn parking and fog lights only when P was pressed. I noticed the other day that now my headlights are popping up. Additionally the right side motor keeps spinning and spinning and usually only lifts the light part way (this seems to coincide with the headlights coming up with the parking light activation). I get if my gear are stripped or bushings are shot, but how would that make the lights start coming up when parking lights are turned on? I replaced the switch too and that had no effect. Will replacing or fixing the actuator/motor fix the headlights popping up with the parking lights?
Chris
Old Aug 25, 2018 | 12:00 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: Headlights suddenly pop up with Parking lights
Do 92 Firebirds come with daytime running lights?
Old Aug 25, 2018 | 12:06 AM
Biggyniner's Avatar
nope
Old Aug 26, 2018 | 01:41 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
This happened on my old Formula, I fixed the gears and it solved all the problems. Hopefully its the same for you too, it was an easy fix.
Old Aug 26, 2018 | 04:50 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I had the same problem with my 92, I put new bushings in and it fixed the problem.
Old Aug 27, 2018 | 06:01 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
That is somehow a "safety mode" or so... If one headlight motor goes bad (bushings & stuff), the headlight module senses that and both headlights will pop up even in park light position. Had to deal with that "problem" a few times, it's normal. Repair your headlight motor thats spinning happily and your problem will be fixed.
Old Dec 11, 2018 | 07:37 PM
Yurview's Avatar
Car: 1991 GTA
Engine: 5.7 TPI
Sorry to bring up an old thread. Recently purchased a 91 GTA. Pass side headlight wouldn't come up. Fixed motor with new bushing kit. Now both lights come up when I turn parking light switch on..... ???
Old Dec 11, 2018 | 07:50 PM
Biggyniner's Avatar
Yup this fixed it for me too.. Weird how that affects lights popping up from using the parking light switch....
Old Dec 11, 2018 | 07:52 PM
Yurview's Avatar
Car: 1991 GTA
Engine: 5.7 TPI
No it didn't fix it. It Started do that After I repaired the bad motor.
Old Dec 11, 2018 | 07:54 PM
Biggyniner's Avatar
Weird... check your otherside.. mine started doing this when one sides "pucks" disintegrated. When I fixed it it worked as normal.
Old Dec 11, 2018 | 08:15 PM
Yurview's Avatar
Car: 1991 GTA
Engine: 5.7 TPI
Roger that .Thanks . Guess I'll tear the other motor apart this wkend
Old Dec 12, 2018 | 02:46 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Exactly what was happening with mine too
florida_gators
Aug 14, 2015 05:15 PM
Rah
Mar 18, 2010 11:02 PM
88fbird
Aug 17, 2004 05:06 PM
WaynesRS
Sep 13, 2002 01:38 PM
