Fan fuse question
Old Oct 6, 2018 | 07:36 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Fan fuse question
Is a fuse supposed to be in this slot? Its C-H fan
Old Oct 7, 2018 | 09:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fan fuse question
Probably not as there is only one terminal for it.
RBob.
Old Oct 7, 2018 | 05:54 PM
RBob.
okay I was wondering because I have 2 fan fuse slots and my fan doesn't kick on by its self
Old Oct 7, 2018 | 07:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, is this this the '85, TPI or carb? Isn't the fuse down two from that location also labeled "FAN?" That is typically for the fan relay coil power, not actual power to the fan. Which the actual fan motor power typically comes from a fusible link.
RBob.
Old Oct 7, 2018 | 07:26 PM
RBob.
85 tpi
Old Oct 8, 2018 | 08:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here is the fan wiring, the relay is mounted to the radiator support (passenger side?).
RBob.
MY87T/A
Jun 11, 2008 07:42 AM
aziroc
Jul 19, 2002 02:44 PM
ChrisFormula355
May 6, 2002 11:46 AM
Kj Rockz
Jan 6, 2002 11:44 PM
