V6 elusive spark. Gurus needed
Old Dec 4, 2018 | 10:01 PM
lcmchefslife's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1L V6
Transmission: Automatic
am stumped. Stopping for the day to regroup. Just need outside help.
Was driving, came to a red light and engine died (no check light came on). Tried to restart and engine would crank but not start. Got the car home via tow. And the initial tests began. Came to find no spark at spark plugs. Time to pull out the repair manual. Started my way down Chart C-4A. Ended up replacing the Ignition Coil, The Module, The Pick-Up Coil, Distributor Cap and Rotor (all were old or used parts I had put in) finally made it all the way down the diagram, still with no spark. So checked the spark plug wires for resistance, they were still good. Checked Fuses, good. Checked Codes, just 12. So I checked the resitance from Aldl Connector 'M' to ECM harness, no breaks. Then went through and checked Volts at ECM harness, all matched up besides: Bypass BC7 (7.3v instead of 0), EST BC8 (6.6v instead of 0), Reference BD8 (10.3v instead of 0), and Reference Low BD9 (10.6v instead of 0). Pulled out wiring diagram, found all wires were from Module to ECM. Thought maybe the resistors in ECM werent closing so I replaced the ECM. Still no Spark, but will crank. Going to recheck volts at ECM in the morning out of curiousity. But now i'm stumped and would like some outside feedback. Any ideas? What am I missing?
ponykiller1992
Jul 7, 2004 12:14 PM
CamaroFreak87
May 17, 2004 08:17 PM
cgb
Feb 28, 2004 08:12 PM
Jstcrzyengh
Apr 19, 2003 07:33 PM
maksik7
Sep 20, 2001 02:32 PM
