Gauge location
Old Feb 8, 2019 | 06:11 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
Gauge location
I was wondering where i can put these so they look a whole lot better. I hate where they are right now. Plus I want to get a mint dash pad soon. I would love to get the OEM cluster working again or even better exchange it for a 140mph cluster and then get the proper controller for the speedo. The car was a 91rsv6 now has a 357 4spd auto
Old Feb 8, 2019 | 06:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Gauge location
If your transmission is a cable drive you can use this Vss and a Dakota digital sgi-5e
https://www.tpiparts.net/inc/sdetail/7587
as for the tach
https://www.thirdgen.org/forums/tran...ds-double.html
the other gauges might look good in a Pilar pod.
Old Feb 8, 2019 | 06:36 PM
Car: 91RS
Re: Gauge location
I bought one of these stuck it in the tranny with red drive gear and of course nothing works
https://www.carparts.com/details/Che...E&gclsrc=aw.ds
Old Feb 8, 2019 | 06:38 PM
Car: 91RS
Re: Gauge location
Thx TP
Old Feb 8, 2019 | 06:43 PM
Engine: Lb9
Transmission: M20
Re: Gauge location
what was the car before 3.1l , tpi or tbi ?
If the car was a 3.1l or tpi is the ecm still in place ?
tbi uses a Vss yellow box next to the ecm.
Old Feb 8, 2019 | 07:48 PM
Car: 91RS
Re: Gauge location
It was a 3.1
Old Feb 8, 2019 | 07:49 PM
Car: 91RS
Re: Gauge location
Tranny is out of a cable firebrd
Old Feb 8, 2019 | 07:50 PM
Engine: Lb9
Transmission: M20
Re: Gauge location
The ecm is a Vss buffer. If it’s gone you need a gm yellow Vss buffer or a Dakota digital unit.
Old Feb 9, 2019 | 03:54 AM
Car: 91RS
Re: Gauge location
Cant find gm yellow vss buffer on ebay
Old Feb 9, 2019 | 11:23 AM
Engine: Lb9
Transmission: M20
Re: Gauge location
https://www.ebay.com/itm/86-91-Buick...er!20876!US!-1
for rear end gear ratio change and to calibrate for the speed sensor gears your better off going with the Dakota digital.
Old Feb 9, 2019 | 04:26 PM
Car: 91RS
Re: Gauge location
the link is not working
Old Feb 9, 2019 | 05:15 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Gauge location
The problem is on your end , the link works fine for me . it's a VSS buffer for $59.99 delivered ....
Old Feb 9, 2019 | 05:42 PM
Car: 91RS
Re: Gauge location
Still not working but keep trying. Thk u
Old Feb 9, 2019 | 06:21 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Gauge location
Old Feb 9, 2019 | 07:07 PM
Car: 91RS
Re: Gauge location
U da man... cant afford it till pd (payday) ... but definitely watching and if it's still there I'll grab it. Thx man.. once I had the part# I found others so no matter what I should be good
Old Feb 9, 2019 | 07:56 PM
Engine: Lb9
Transmission: M20
Re: Gauge location
The speedometer wire is in connector c207 by where the ecm use to be .
Old Feb 9, 2019 | 10:19 PM
Car: 91RS
Re: Gauge location
10-4
Steve86TA
Nov 24, 2006 08:02 AM
Steve86TA
Exterior Parts for Sale
Oct 29, 2006 02:12 PM
Steve86TA
Oct 29, 2006 02:10 PM
Steve86TA
Oct 29, 2006 02:08 PM
TravisZ28MAXX
South East Region
Nov 16, 2003 06:43 PM
