toggle switch for brake lights...?
Old Jan 8, 2002 | 09:29 PM
CamaroEFI's Avatar
i was thinking it would be cool to hook a toggle switch to the brake lights. would this be difficult? how would i do this?
Old Jan 8, 2002 | 09:35 PM
92RSB4C's Avatar
Just curious, why would you want to toggle your brake lights?
KidTransAm's Avatar
piece of cake man...all you have to do is take a probe and find the brake power wire in the drivers kick panel and cut it..run a couple wires up to your switch and ur done. late night law enforcement evasion
Old Jan 8, 2002 | 09:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Or splice a switch into the brake switch at, where else?.... the brake pedal.
I, too, am curious for the need of this.
Old Jan 8, 2002 | 10:10 PM
KidTransAm's Avatar
me and my buddy decided to do this after we got caught trying to evade a ticket..we only got caught because he saw our brake lights light up when we turned off on a back road....(head lights were out)..just something else to mess with
Old Jan 8, 2002 | 10:21 PM
deadbird's Avatar
Engine: TPI 305/ v6
That's brilliant,
Old Jan 8, 2002 | 10:31 PM
CamaroEFI's Avatar
kidtransam has the reason. cops will pull you if they see you hit your break when you think you're about to be caught speeding. you could slow down without being suspicious.
Old Jan 9, 2002 | 01:18 PM
89 CamaroIROCZ's Avatar
is that insurance fraud i smell in the air??? <sniff sniff>.......
I knew a guy who knew a guy who did this and apparently got alot of money before he got locked up. Something to ponder.
Matt
Old Jan 10, 2002 | 08:11 PM
CamaroEFI's Avatar
How would that be insurance fraud? turn the brakes off and let someone hit me? i don't need money that bad
Old Jan 12, 2002 | 08:36 PM
88_RS&86_Z-28's Avatar
some drag racers use it so they can sandbag they dail in slower and when it comes time to race flip the switch race just before the finish line hit the brakes they win its cheating and i dont do it but i know alot of them that do. just my 2 cents
Old Jan 14, 2002 | 09:55 AM
However what i said was a simple comment not implying that you were going to do that. And you shouldn't be so quick to jump down my throat being that putting a toggle switch on your rear brake lights is illegal and basically could be used for nothing but illegal purposes. I.E. Evading arrest.
Matt "Straight Arrow" Genaro
Remember that movie?? what was it called....
EDIT: NECESSARY ROUGHNESS! Good flick.
Old Jan 14, 2002 | 07:26 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
If you look hard enough you can probably find a switch designed for this. I've seen one in a catalog before and I'm 90% sure that it was J.C. Whitney, but I might be wrong. It might have been in a catalog for law enforcement equipment like Galls. I have seen this before somewhere though.
Old Jan 14, 2002 | 09:40 PM
Omar's Avatar
You dont need to go around looking for a switch. Just go buy a $2 toggle switch at your local parts store. Locate the switch at the top of the brake pedal. Using a test light or meter, find the one that is ALWAYS hot. Cut it and wire the switch into it.
While you are at it, find the brown wire that runs behind the driver kick panel. This feeds 12V to the parking lamps and tail lamps. Wire a second toggle for this, or even the same toggle switch as before. Now you can have NOTHING but the headlights on.
Make sure you use a toggle switch with the proper amp rating.
Make sure you let us know which police auction your car will be at.
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Aug 21, 2015 01:54 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
