L98 no start
L98 no start
Hi all installing l98 into my 61 c10. Installed using painless harness. Fired up several times and then one day no start.
ohmed all injectors (16). Provided 12 volts to reference signal to ecm and noid light fired. 42lbs fuel pressure. Stumped any help would be appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: L98 no start
What 12v reference pin did you supply 12v to ?
1227165 or 1227730 ecm ?
Do you have spark ?
Do you have spark ?
Engine: Lb9
Transmission: M20
Re: L98 no start
B5 purple/white ?
Sounds like a good way to blow the ecm.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Re: L98 no start
Re: L98 no start
That’s what I thought but changed out icm and ohmed out harness. Do any of the map relays come into play on startup. Sprayed starting fluid and unit fired up and would stay running .
Engine: Lb9
Transmission: M20
Re: L98 no start
Can you view ecm data with tuner pro rt or hand held scanner.
It seems like the ecm is not seeing drp on startup. The reference pulse voltage must be low or the ecm is bad not seeing atleast 400 rpm.
The maf power relay has no connection with having injector pulse or not.
I wonder if you have two issues a bad icm now replaces and a bad ecm.
Re: L98 no start
I agree that it is not seeing a reference pulse. The only thing that has got me stumped is I have 2 ecm’s and when I was able to start truck I swapped ecm’s and 2nd one ran truck. Now neither one will. Maybe I’ll pick up another icm and see if that works. You can see where my frustration comes from.
Engine: Lb9
Transmission: M20
Re: L98 no start
If you applied 12v to the reference on both ecms that might fry them. Reference voltage is only 1.5v running.
Re: L98 no start
digging a little deeper into no start, no injector pulse. i am getting a 3vdc reading on EST bypass terminal at D5 and should be reading 0vdc. does anyone think this would hold out injectors on startup. this is a intermittent problem where sometimes truck will start right up and sometimes will not rum at all unless i use start fluid and will remain running
Engine: Lb9
Transmission: M20
Re: L98 no start
Have you checked to see if the ecm is powered up during the no start.
running d5 is 4.75v .
http://chevythunder.com/fuel%20injec...ecm%20#1227165)
I don’t think the bypass has anything to do with the no injector pulse.
maybe b5 if anything.
Re: L98 no start
success!! thanks to scott at tuned performance where i had my chip programmed. he pointed me in the right direction that i was loosing power to my computer on startup. traced back and found broke wire , repaired and starts right up. thanks again
Dan87IROC-Z
Mar 26, 2001 05:32 AM
