Is an iron headed L98 really an L98?
Old Oct 23, 2001 | 10:42 PM
Tas's Avatar
Tas
Is it really an L98 or does it have its own engine code seperate from the vette, aluminum headed l98?
Old Oct 23, 2001 | 10:47 PM
breathment's Avatar
well since the RPO code is L98, i would assume that the iron head 5.7L is an L98. since the only difference with the vett is the heads and exhaust.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 24, 2001 | 12:39 AM
silverstreakII's Avatar
well, ive heard that the designation given to the non aluminum headed tpi 350 was B2L, but it might not be true. yyou could probably call a dealer and find out though.
Old Oct 24, 2001 | 03:46 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Its an L98 with iron heads, thats all. B2L is the option code for ordering the L98 engine combination in a Third Gen.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Yeah I have an RS, but I want an IROC-Z!!
[This message has been edited by IROCZTWENTYGR8 (edited October 24, 2001).]
Old Oct 24, 2001 | 01:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
GM committed the unforgivable error of giving 2 significantly different engines the same "L" number. The original L98, which came in Vettes, had 58cc aluminum heads without an exhaust crossover passage; the later F-body L98 had cast-iron 64cc heads with the exhaust passage. They were mostly similar otherwise.
B2L was the RPO option code that you ordered for installing the L98 engine into a F car. B2L is not an engine.
ICON Motorsports
Old Oct 24, 2001 | 03:02 PM
u r sofa king we tah did's Avatar
the original L98 came with iron heads in the vette, in 85 and early 86.
Old Oct 24, 2001 | 08:28 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
B2L is the code for the aluminum head delete option, aka iron heads
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Oct 24, 2001 | 10:08 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
that isn't correct, it is as stated previous. B2L is just the option package for the L98 engine. included more than just the engine.
Old Oct 24, 2001 | 10:33 PM
breathment's Avatar
my iron headed GTA has a L98 RPO code,
- David
Old Oct 24, 2001 | 10:35 PM
breathment's Avatar
https://www.thirdgen.org/messgboard/...ML/000559.html
irocztwenty seems to correct im my opinon on this one
- David
[This message has been edited by breathment (edited October 24, 2001).]
Old Oct 25, 2001 | 09:31 AM
Iroc n roll's Avatar
Yeah ditto. The L98 code refers to the block in this case regardless of heads.
lt500r55
Sep 1, 2021 01:30 PM
Chuck84TA
Jul 15, 2016 09:05 PM
InfinityShade
Feb 21, 2016 01:29 PM
italiano67
Aug 31, 2015 06:04 PM
