1982 Trans Am doesn’t start and spies don’t flash on dashboard at start
Old May 18, 2019 | 05:37 PM
coxboy's Avatar
Car: 1982 Trans Am
Engine: 5.0 Crossfire
Hello Transammers,
I picked up a 1982 Trans Am 5.0 Crossfire, the engine rotates but won’t start. I checked out and replaced sparks’ wires and sparks were replaced by previous owner.
I saw that during I’m turning on, there are no spies/lights on dashboard that are flashing/coming on. Furthermore if I put an obd1 adapter to obd2 reader, the reader has no lights turning on (like it doesn’t receive any electricity). The ECM was replaced and I don’t know how ‘it was replaced’ as long as sparks.. I replaced also fuel filter. The fuel I see that comes as well til the carbs. I think I said all. I think could be a electrical wire. Let me know gurus. Thank you!
Old May 19, 2019 | 01:24 AM
GeneralDisorder's Avatar
Re: 1982 Trans Am doesn’t start and spies don’t flash on dashboard at start
Have you checked for spark and injector pulse?
GD
Old May 19, 2019 | 06:27 AM
coxboy's Avatar
Car: 1982 Trans Am
GD
No I didn’t. Anyway there are lights (engine service) off on my dashboard, this could help us to solve the problem?
Old May 19, 2019 | 09:38 AM
You can troubleshoot it however you like. If you want to trace the SES light then pull the diagram and trace it. Sounds like you have a plan.
I would start with spark and injector pulse.
The twin-toilet injection is not known for being reliable or easy to work on. You have an uphill battle. I suggest you get a scope so you can properly test your components.
GD
WagonmasterRuss
Nov 24, 2014 10:17 PM
xavier_pr84
Aug 18, 2012 04:11 PM
badassstroker
Mar 25, 2009 10:56 PM
slrvette
Jul 21, 2008 06:49 PM
