Won't start
Old Apr 23, 2019 | 08:33 PM
88formula5spd's Avatar
Won't start
Hi everyone, my dad was trying to start my 1988 305 formula when he saw a plume of smoke come from the passenger side near the tap of the engine bay(through the mesh near the wipers). The car will not start, it won't even turn over, and it seems as if there is no power going to the ignition at all. The interior lights work, the horn works, the headlamps works, and the trunk release works. The headlights won't flip up, although they get a power reading when the switch is off, but the 12 volt signal is lost when I hit the switch to flip them up. They windows won't roll up, the dash lights won't turn on, and I'm overall lost. I tried to connect aldl A and B for diagnostic but the light won't turn on. Help pls!!!
Old Apr 23, 2019 | 08:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Won't start
Look at the fusable links. They are on the starter .
Old Apr 23, 2019 | 08:51 PM
Re: Won't start
Can I see them from underneath the car near the starter or do I have to look from above? From what I've read those things are real fun to get at.
Old Apr 23, 2019 | 08:55 PM
Engine: Lb9
Transmission: M20
Re: Won't start
There’s not much slack in the wiring. You can get to them under the car.
Old Apr 23, 2019 | 09:35 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: Won't start
Please check the braided ground strap at the rear of the passenger side head. I too just had a small puff of smoke up near the front of my engine bay on a hard start, it was the broken ground wire from the battery to body...
Old May 8, 2019 | 11:37 PM
Re: Won't start
Got it! It was a fuse able link.
Old May 19, 2019 | 01:01 AM
coxboy's Avatar
Car: 1982 Trans Am
Engine: 5.0 Crossfire
Re: Won't start
88formula5spd I think I have the same problem, can you explain how repaired it? Thanks
Old May 19, 2019 | 10:52 PM
Re: Won't start
Will do, I'll try and post pictures and an explanation tomorrow.
Old May 20, 2019 | 12:57 PM
Re: Won't start
1. Go under the car and look for the starter. Check the connections to the terminals, then use a test light to check if there is any power going through the wires between the fusable links and the starter with the ignition in the on position.
2. If there is no voltage reading, it's probably the links. I tried arching the wire before the links to the terminal on the starter and for me there was power when I bypassed the links. (Probably wouldn't recommend doing that in case if a surge).
Old May 20, 2019 | 03:36 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Won't start
The question though is why did the fusable link pop? Are you running aftermarket equipment (amps etc) off the internal car wiring? Either you have something pulling too many amps, a short to ground, or a bad ground from engine to frame.
And yes with the link bypassed what ever popped it the next time will catch on fire so I would replace them. The part stores sell them they look like little pieces of wire you just cut and crimp them in.
paintballer687
Jan 23, 2009 11:45 PM
dperk
Feb 16, 2005 01:28 PM
Free Bird
Feb 15, 2005 01:11 PM
84 Challenge
Jul 21, 2003 07:12 PM
