I honestly don’t know
Old Jun 26, 2019 | 09:59 PM
Stevenmunoz's Avatar
Car: 1987 Firebird
Engine: 2.8L V6
So over the past four days I have been battling with doing a torque converter swap on my 1987 Pontiac Firebird 2.8 V6 the torque converter went in and it seems to go into gear well but all of a sudden the engine starts messing really bad to the point where it will shut itself off and won’t idle it seems like it’s getting fuel because when I would spray brake clean it in there nothing would change but I don’t Believe it is getting spark all the time the only thing I did was take off the distributor cap, and now while typing this I realize that maybe that little spring in there could make it do that but it just seems so weird to me… Could it be a messed up ground from when I took out the Trans, Any and all help would be appreciated
Old Jun 27, 2019 | 03:30 PM
GeneralDisorder's Avatar
Re: I honestly don’t know
Tell us more about this "little spring" you speak of. What happened with this? Specifics.
GD
Old Jun 27, 2019 | 04:42 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Stock torque converter? if its locking up on you it can stall the engine. Does it do it if you are on flat ground and just let it drive at idle speed?
Yes if you had the cap off and the parts are old the contacts on the rotor could of gotten messed up. Its also possible to put the cap on 180 degrees off on the V6 I think. Did you have the wires off the cap? could you have gotten the firing order wrong?
There is a ground strap on the back of the engine/heads but I doubt you messed that up, but worth looking.
Possible you messed with the timing or left something unplugged if you were messing around the distributor.
Also you could of moved a plug wire so it melted on the header.
A good visual inspection of everything should rule out alot.
Old Jun 27, 2019 | 10:57 PM
Car: 1987 Firebird
Engine: 2.8L V6
I figured out what it was today. My “friend” broke my distributor cap but didn’t wanna make me mad apparently so just left it and it wasn’t sparking in cylinders 2,3 or 5 so that was fun! Thank you all for your help!
jester111
Jan 12, 2003 05:25 PM
85CamaroRulz
Apr 5, 2002 07:17 PM
iroc22
Dec 21, 2001 04:40 PM
86rubyredLG4
Feb 1, 2001 07:15 PM
ChrisFormula355
Nov 13, 2000 12:42 PM
