90 92 infl rest sensor position
Old Jul 13, 2019 | 03:09 PM
Mick Keinedaten's Avatar
Car: camaro 91 z28
Transmission: AT
Hello.
In my 91 z28 the pre owner removed the airbag front sensor and cutted the wires.
Now I got a used sensor and the whole headlight harness.
But I don't know where to put the sensor. I can't see any wholes where to bolt it.
Does someone have a picture or can make one of the location?
Old Jul 13, 2019 | 03:43 PM
Drew's Avatar
Re: 90 92 infl rest sensor position
It's on the rad support under the hood latch.
Old Jul 14, 2019 | 10:58 AM
Car: camaro 91 z28
Transmission: AT
Ok I have searched everything in the internet and now I know where it should be.
Seems like someone in the past changed the radiator support because the upper support on mine doesnt have the bracket where the sensor is screwed.
Now everything makes sense why they cutted the sensor changed the steering wheel and pulled out the infl rest bulb in the gauge.
There had to be an accident in the past..
Old Jul 14, 2019 | 11:39 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
The service manual goes to great detail on how to mount this sensor. they seemed pretty sensitive about it. there are 2 small screws up front, and two 10mm bolts in back that secure the bracket. not quite sure why the back wasn't welded rather than bolted. The front part of the bracket is welded.
Old Jul 14, 2019 | 12:46 PM
Drew's Avatar
If you really want to put it back, I've got the bracket out in the scrap pile.
MrJ
Dec 19, 2001 03:00 AM
MouseCamaro305
Dec 18, 2001 09:32 PM
Camaro90RS43
Nov 29, 2001 12:25 AM
TransAm1982 305
Jul 15, 2001 08:14 PM
turbovsix
Jun 27, 2001 02:40 PM
