LED Headlight Harness Questions
Old Jul 19, 2019 | 11:11 PM
Crossfire1983's Avatar
Car: 1983 Chevrolet Camaro Z28
Engine: LS3
Transmission: Tick TR6060 w/ Mantic 9000 clutch
Axle/Gears: Strange S60 w/ 3.73 True Trac
On my 83 Camaro I want to convert the headlights to LEDs, preferably the Vision X Vortex 4 x 6 or the Trucklite 4 x 6. How would I get it so in low beam mode, all 4 are on in low beam mode and in high beam mode all 4 are on as well? If I go with the Vision X lights, they have high and low in one unit as well as a halo that I would like to hook up to the marker lights (first click of the headlight switch) and would like to run all 4 headlights on in both high and low. Would I have to have a custom harness made or does a product exist that I can plug and play with?
Old Jul 20, 2019 | 11:49 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: LED Headlight Harness Questions
You'll have to re-wire it with relays. There is a kit that most people buy to do this, it plugs into the existing sockets and wiring and only requires you to run a power wire. I bought mine on Summit years ago but I can't remember which one it was. Do a quick search of these boards and you should get the answer. Alternatively if you understand wiring schematics you could build your own setup at the cost of a few wires and two relays.
Old Jul 20, 2019 | 12:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Here it is although it appears that Summit doesn't sell it anymore: https://www.summitracing.com/parts/GRM-01-133/
Also you should read this how to since it shows how to wire them without a kit: https://www.thirdgen.org/headlightupgrade/
Old Jul 20, 2019 | 07:58 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Making the harness would not be hard, but getting the proper 59 series Packard terminals is a little difficult. American Autowire sells them, but they are kind if expensive from them. I found the "single wire" terminals, but you really need the dual wire terminals since you would be putting them all in series and have to double up the wire in each terminal to go to the next one. Factory wire size for the headlight harness is 16 gauge too, don't skimp on this if you do build your own, you may even consider going up to 14 since having 4 LEDs burning at once is going to be a considerable current draw
SC/T02
May 21, 2017 08:48 AM
cdoyle
Apr 9, 2012 09:38 PM
Firebirdstu
Exterior Parts Wanted
Jun 11, 2009 12:30 PM
Iroc-N-Rollz!
Apr 8, 2009 09:32 AM
