What does this wire go to?
Old Aug 8, 2019 | 08:38 PM
Nuke82's Avatar
Car: 1986 Firebird Trans Am
Axle/Gears: 308
So I was performing some mx on my newly acquired 1986 Trans Am, 305 TPI, and found this green wire just laying near the distributor. I looked all over and can't find what it goes in. I looked on the forums here and couldn't find anything either. Anyone have a clue what thos single solid dark green wire is?
Old Aug 8, 2019 | 08:56 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: What does this wire go to?
Check to see if your egr has the sensor on it. This might be the plug for that. Is your SES light on?
Old Aug 8, 2019 | 09:38 PM
Nuke82's Avatar
Axle/Gears: 308
My EGR solenoid is a two wire black/purple and grey
Old Aug 8, 2019 | 09:44 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Looks like the egr temp switch connector, I just replaced mine on the GTA recently and that looks like it. As another poster asked is the check engine light on??
Old Aug 8, 2019 | 10:02 PM
Nuke82's Avatar
Axle/Gears: 308
No, no check engine light. Everything works but the ac.
That's it though, wonder why it hasn't thrown a code
Old Aug 9, 2019 | 10:55 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Does the CE light come on when you first start the engine (as a means of self-checking it's function)?
Old Aug 9, 2019 | 11:42 AM
Nuke82's Avatar
Axle/Gears: 308
Yes, the light comes on when I put the ignition in the in position.
Old Jun 17, 2023 | 08:27 PM
Radron's Avatar
Car: 85 iroc
Engine: 350 tpi dropped in
Sorry replying to an old post but I'm just putting my car back together. Anyone ever figure this connector out?
Old Jun 19, 2023 | 06:40 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
EGR Temperature Diagnostic Switch
Old Jun 19, 2023 | 07:18 PM
Radron's Avatar
Car: 85 iroc
This might be a dumb question, So there's a place on the egr under the plenum to connect to.
Old Jun 20, 2023 | 05:42 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
The temperature diagnostic switch is essentially a temperature sensor. The sensor wire is routed along the passenger side fuel rail (IIRC). It looks like this:
The sensor screws into the base of the EGR valve. It tells the ECU when the EGR is opened by sensing the rise in temperature.
Old Jun 20, 2023 | 07:00 PM
Radron's Avatar
Car: 85 iroc
Very cool. Thank you
KILLAZMOTO
Mar 24, 2017 05:24 PM
SRKLEGIN
Aug 15, 2014 12:48 PM
Notplayn
Feb 25, 2005 11:59 PM
ORAY777
May 19, 2002 06:40 AM
Beast5spdGTA
Apr 9, 2002 07:53 AM
