No Power to Trunk Pull down Motor 86 Firebird
Old Aug 12, 2019 | 08:08 AM
Fragale81's Avatar
Car: 86 Firebird
Needing some help, I have no power to my rear trunk pull down motor. I have seen many post about check the fuse labeled LID i don't have that. I have checked all the fuses in the box and nothing is blown. I have also read about an inline fuse but do not see that anywhere. The battery is charged and connected i am getting power to the light in the trunk but nothing to the trunk motor. Anyone have any suggestions? This is for an 86 Firebird, 305 engine, it doesn't have power door and windows.
Old Aug 12, 2019 | 09:49 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: No Power to Trunk Pull down Motor 86 Firebird
The inline fuse is a spade fuse under the driver dash. Its typically somewhere around the fuse box, but its just a spade fuse on the wire.. The light and motor are on different circuits Its been a while since I rebuilt my trunk mechanism but I believe there is also a relay in the trunk area.
When you say no power is it at the relay, contact switches, or at the motor that you are testing?
Old Aug 12, 2019 | 10:37 AM
Fragale81's Avatar
Car: 86 Firebird
I am actually checking at the power wire coming in. I have completely disconnected the motor and relay, I am test at red wire coming to the connection for the motor harness. I have read that this is HOT all the time but i am getting nothing on the meter.
Old Aug 13, 2019 | 11:21 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If your not getting power at the back of the car,... then you will have to move to the front of the car to find out where you are losing power. As previously described, you should start here:
Old Aug 14, 2019 | 07:12 AM
Fragale81's Avatar
Car: 86 Firebird
Thanks that is what i needed to know.
Old Aug 24, 2019 | 02:47 PM
Fragale81's Avatar
Car: 86 Firebird
Ok, just adding these photos but i think i'm losing it, i can't seem to find any type of inline fuse anywhere. There is what i thought might be a fuse, it has the black tape with blue line but it is a resistor. By any chance would anyone have a photo of this fuse. This is on an 86 Firebird. and i have no power to the rear trunk motor, which according to the prints the red/white wire should be hot all the time and i have nothing. As you can see also by the fuse panel I don't have a "lid" fuse either
Old Aug 24, 2019 | 04:18 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
on a 89 Firebird
Old Aug 24, 2019 | 07:03 PM
Fragale81's Avatar
Car: 86 Firebird
Appreciate the hell out of the picture, just went and checked again for the 10th one ha ha. I don’t have anything like that. I even dropped the fuse block to check behind. Any chance anyone out there has an 86 and had to change this?
Old Aug 24, 2019 | 07:18 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
There is the convenance center box under driver dash close to the radio pod. It's hard to get to but it has things like the flasher and if your car had it factory amp fuse and a few others. It will swing down after remove a couple screws. Check there.
If not reach out to Lon atTop down solutions he wrote the book on repairing the pull downs.
Old Aug 24, 2019 | 07:26 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
@lonsal is his user name here. Also read through this.
https://www.thirdgen.org/forums/inte...you-hatch.html
Old Aug 24, 2019 | 07:34 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
May be useful, seems not all 86s had the pull down. This link has scans from service manual specific for 86.
https://www.thirdgen.org/forums/elec...tion-info.html
Old Aug 25, 2019 | 05:08 PM
Fragale81's Avatar
Car: 86 Firebird
Hey Guys,
Thanks for all the help. I finally found the fuse, it was very well tucked away and taped up on but it was right above the fuse box
Old Aug 25, 2019 | 07:49 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Originally Posted by Fragale81
Hey Guys,
Great so was it the fuse?
Old Aug 26, 2019 | 11:09 AM
Fragale81's Avatar
Car: 86 Firebird
Well Yes and No, the fuse was blown, and when i put a new in it blew. So i have a grounded wire or something now. But good side is i narrowed it down the the Harness on the trunk motor, so hopefully figure that out now.
Old Aug 26, 2019 | 01:28 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Sounds good I would start by disconnecting the plugs in the back. If still short to ground. Two places to look. Under the door sill and make sure the wire hasn't gotten pinched where the steering wheel mounts under dash.
Old Aug 26, 2019 | 02:42 PM
OrangeBird's Avatar
Car: 1989 Firebird
Both places are great suggestions to look for the short (if it's still there with the pulldown mechanism unplugged , that is) , and here is one more ;
In the lockable compartment in the trunk on the left side , there is supposed to be a cardboard enclosure that's kinda similar to the glove compartment in the dash on most other cars . When that cardboard deteriorates and ends up thrown away people sometimes store tools & things in there because without the cardboard box there's a lot of room in there . All the wires that go to the back of the car run through there and at least twice over the years I've seen third gens with mystery shorts in the back of the car end up being those wires squashed/shorted by stuff stored there .
Maybe , maybe not , but worth a look if the cardboard box isn't there to see how the wires there look , condition wise ...
Old Aug 26, 2019 | 03:40 PM
Fragale81's Avatar
Car: 86 Firebird
I haven't had a chance to look yet but i know i am good from the fuse all the way back to the trunk, I am now getting 12volts at the connection. So it is for sure in the wiring/plug of the motor itself. The actually motor isn't hooked up at the moment but i blow the fuse when i connect the harness to the red/white wire connection. I will let you know what i find when i get a few to get out there and look.
fishhook86
Feb 17, 2012 11:42 AM
valentinfranco
Oct 16, 2011 05:35 PM
foc400
Jul 2, 2008 12:03 PM
wildlogger3371
Sep 5, 2004 02:59 PM
Demon355
Sep 4, 2002 08:53 PM
