Vats system
Old Sep 2, 2019 | 12:59 PM
Skipin45's Avatar
Car: 1990 camaro
Vats system
I have a 1990 camaro. It started pulled out of garage turned it off did some work in garage. Sat for a couple of hours went to start and nothing. Last time this happend it was the chip in key was damaged bought new onecand started right up. I've tested key in ignition with vats unplugged and turned key tested good. 4. 75. Put metter on other end on purple white and white and it reads -3. 57 can't get a positive reading. I have the meter on 20 k ohms. If I flip wires it reads 1. Ive checked fuse fuse is good. Please help car is stuck outside.
Old Sep 2, 2019 | 01:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vats system
Are you sure your checking the right wires. Should be two white wires in a orange sheath.
Old Sep 2, 2019 | 01:38 PM
Engine: Lb9
Transmission: M20
Re: Vats system
Old Sep 2, 2019 | 01:46 PM
Skipin45's Avatar
Car: 1990 camaro
Re: Vats system
Yes, one side of connected with orange wire goes to ignition the other side of conecter goes to module.
Skipin45
Sep 3, 2019 01:09 PM
VEGASIROC
Jun 5, 2011 12:04 AM
vswearingin
Aug 14, 2008 08:40 PM
91WhiteCamaro
Jan 11, 2007 11:43 PM
AFast83z28
Dec 11, 2002 07:17 PM
