Plug identification HELP
Old Oct 18, 2019 | 08:53 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
Looking for the names of two connectors. Hoping to buy them from an electronics store instead of searching the bone yard for them. Ls swap. Basically trying to splice fuel system wiring together.
the first is the 3 wire fuel sender connector to body
second is 4th gen 4 pin fuel sender
to be clear im looking for the plugs that go into the circled connectors
Sorry for the low level terminology
Old Oct 18, 2019 | 10:09 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Plug identification HELP
Maybe this - https://www.ebay.com/itm/Delphi-GM-3...EAAOSw9DVZudFW
And this - https://www.ebay.com/itm/Weather-Pac...kAAOSwepNdB-lP
Hopefully someone else can confirm. They look like standard GM weather pak fair to me though.
Old Oct 19, 2019 | 12:43 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Gm weatherpack! Yes! Thank you i couldnt remember the actual names of these.
Old Oct 19, 2019 | 03:38 AM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
You are very welcome. I hope it helps !
Old Oct 20, 2019 | 01:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Or metri-pack, as its called now, weather pack was the old 80/90s style.
jd25
Jun 10, 2018 08:24 PM
kevwalt22
Dec 21, 2016 01:05 PM
DJ Delsym
Feb 8, 2009 01:08 PM
85ZzZ4
Apr 8, 2008 03:39 PM
ir0cz
Mar 26, 2002 09:33 PM
