OIL pressure sender/switch question
Old Nov 25, 2019 | 07:10 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Hi everyone, here’s the question: I bought a new oil pressure sensor and a new connector (3.1 LH0 engine). This one came with only two wires instead of three as I have on the car (part number PT2324). Do I need the right connector or can I put on the two-wires one? Thank you!!
Old Nov 25, 2019 | 10:42 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: OIL pressure sender/switch question
The 3rd wire is for gauge or idiot light. A 2 wire will work in place of a 3 wire if you do not have a gauge or light.
Old Nov 25, 2019 | 11:12 AM
Engine: 3.1 LH0
I’ve a gauge, so I’ll need that wire. Thank you!!
Old Nov 25, 2019 | 11:24 AM
Engine: Lb9
Transmission: M20
Does the plug look like this ?
https://www.eficonnection.com/home/p...nector-pigtail
Old Nov 25, 2019 | 01:12 PM
Engine: 3.1 LH0
Yes, it’ s the same
Old Nov 25, 2019 | 01:16 PM
Engine: Lb9
Transmission: M20
looking at RockAuto.com it shows the same oil pressure switch for tpi and 3.1l. Should be the same connector.
Old Nov 25, 2019 | 01:59 PM
Engine: 3.1 LH0
That’s the strange thing, even though the same part number the connector came without one wire. Meanwhile I replaced the sender with the old connector...
bad to be blown
Jul 6, 2011 03:45 AM
88TransAmFreak
Jun 24, 2010 01:20 AM
mantiz85ws6
Dec 15, 2005 05:00 PM
camaroracer1
Aug 29, 2002 09:10 PM
