Fixing Speedometer & Tachometer After Engine Harness Replacement
Old Jan 14, 2020 | 11:13 AM
kaupca's Avatar
Car: 92 Camaro RS
There is a tech article about this but one part is unclear to me. Are the wires removed from the VSS buffer box and inserted into the ecm connector or what is the connection process?
Old Jan 14, 2020 | 11:25 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fixing Speedometer & Tachometer After Engine Harness Replacement
What tech article are you referring to ?
Did you go from tbi to tpi ?
Old Jan 15, 2020 | 09:00 AM
kaupca's Avatar
Car: 92 Camaro RS
Here is the link
https://www.thirdgen.org/tbi-tpi-fixing-speedo-tach
Yes the car was converted from TBI to TPI
Old Jan 15, 2020 | 10:55 AM
Engine: Lb9
Transmission: M20
The link doesn’t work, if you went from tbi to the 730 ecm you can use the Vss buffer with reprogramming so the 730 input is optical. Or wire it directly from the Vss pin b9 purple b10 yellow wire. The output to the cluster gets moved over from the buffer to pin b11.
if you went tpi maf leave the Vss buffer inplace and hook the 2k ppm wire to pin a 10.
Old Jan 16, 2020 | 04:37 PM
Drew's Avatar
Cut/Paste works https://www.thirdgen.org/tbi-tpi-fixing-speedo-tach/
Pretty sure he's saying unplug the VSS buffer box and extend the wires from the VSS buffer box plug to the ECM.
Old Jan 17, 2020 | 09:42 AM
kaupca's Avatar
Car: 92 Camaro RS
To Tuned Performance
Do you agree with this?To get the speedometer and cruise control to work on a 92 TBI car converted to a 1227730 ecu (or 1227749):
-remove the VSS buffer
-connect pin 5 from the VSS buffer harness connector to C1 on the 7730ecu
-connect pin 6 from the VSS buffer harness connector to B11 on the 7730
The wires from C1 and B11 go to the C207 connector and connect to NOTHING, so I cut the wires at the C207 so I didn’t have to extend them to connect to the VSS buffer connector
Old Jan 17, 2020 | 10:13 AM
Engine: Lb9
Transmission: M20
C1 goes to cruise control on the 730
B11 to the instrument panel
I believe the Vss buffer has letters on it not numbers.
I think you have it correct
Old Jan 21, 2020 | 03:26 PM
kaupca's Avatar
Car: 92 Camaro RS
Thank you everyone for your assistance/comments. Connected it up and speedometer works!
tonys91rs
Sep 16, 2012 11:48 AM
j.a.s
May 20, 2008 11:33 AM
Dirtbik3r
Mar 6, 2006 06:40 AM
MochaX
Jun 6, 2003 10:22 PM
