92 Firebird 350 swap wire harness Help
Old Apr 5, 2020 | 06:01 PM
Firefighter84's Avatar
Car: 1992 firebird
Engine: sbc 350
Transmission: th 350
I am just getting back to finishing up my bird, however I'm lost with what wires to keep and which ones to toss. Does anyone have a good wiring diagram to follow ? I've tried the autozone site and I'm having a hard time figuring it out .
Old Apr 5, 2020 | 06:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 Firebird 350 swap wire harness Help
Tuned port injection ?
Old Apr 5, 2020 | 06:22 PM
Car: 1992 firebird
Engine: sbc 350
it has a carburetor
Old Apr 5, 2020 | 06:28 PM
Engine: Lb9
Transmission: M20
The 92 never came with a carb 3.1l , tbi 305 or 305 & 350 tpi.
are you stripping down a harness ?
Old Apr 5, 2020 | 06:53 PM
Car: 1992 firebird
Engine: sbc 350
Pretty much starting from scratch this is a car that I swapped the original motor for a sbc 350. I'm having trouble figuring out what wires are not necessary, trying to incorporate wiring for the motor itself and then rewiring some of the oem items such as radio, windows, lock, and so on. This is my first build so I thought I would reach out to more experienced lol
Old Apr 5, 2020 | 07:04 PM
Engine: Lb9
Transmission: M20
First off what was the car originally?
I listed the options
Are you regulating down the in tank pump ?
Old Apr 5, 2020 | 07:09 PM
Car: 1992 firebird
Engine: sbc 350
I believe it was the 305 tbi
What do you mean by regulating down the pump ?
Old Apr 5, 2020 | 07:45 PM
Engine: Lb9
Transmission: M20
Your fuel pump if in tank the pressure is to much for a carb.
buying a service manual would really help you out. eBay has good deals.
http://www.austinthirdgen.org/?pid=19
or you can use the above
power to the cab is provided by the fusible links at the starter.
the passengers side harness can be removed through the pass through connectors under the rh side kick panel.
You would still need to have power and tach to the distributor
green wire to cylinder head temp sender.
alternator wiring. The fan can remain if you use a temp sender in the passenger side head.
Old Apr 6, 2020 | 08:28 AM
Car: 1992 firebird
Engine: sbc 350
Thank you for the help !
Strigon1
Dec 6, 2018 11:23 PM
92projectcamaro
Oct 6, 2015 08:56 PM
meso5012
Sep 10, 2011 08:33 AM
bonesbrakr
Mar 30, 2009 08:58 PM
