How many miles to drive with new battery before smog.
Old Apr 16, 2020 | 12:44 AM
Kamerokid's Avatar
Car: 1992 Black Chevy Camaro RS
Engine: 305 V-8 (IROC engine)
Transmission: Automatic
Axle/Gears: 700R4
I need to get my 92 Camaro smogged. I just reconnected my battery since I don't drive it that often. I've seen so many different answers online about how many miles to drive. Some say 50 miles, others say 100 to 200 miles over a week to complete one drive cycle. I'm sure with the latter they're talking about newer cars. Though, I can't find anywhere online if this also applies to my 92 Camaro. I just drove it 65 miles today and I plan on driving it for another 20 minutes or 15 miles before I take it to get smogged. Is this enough? Thank you all for your feedback! Much appreciate appreciated!
Old Apr 16, 2020 | 02:40 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: How many miles to drive with new battery before smog.
All you need to do is drive it far enough to get the converter hot. How far is it to the inspection place? That should be enough.
Gas is cheap right now, even by CA standards so if you feel the need to drive around for an hour and a half, it won't hurt but it won't do much good either.
Old Apr 16, 2020 | 05:45 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
My 2000 Silverado needs 50 miles before it does a system check and will show a code
Old Apr 16, 2020 | 07:06 AM
OrangeBird's Avatar
Car: 1989 Firebird
And that's because your 2000 truck is an OBD2 system that does record engine performance data which is readable by the smog check computer . Disconnecting the battery dumps that data that the smog check needs , so around 50 or so miles are required to build up that data . Our cars are all OBD1 , and in the State where I live there is no OBD1 connection to the smog computer .
KameroKid , does California have the smog tech connect anything to the ALDL during the inspection ? If not , warm it up good on your way to the smog check and don't worry about any specific number of miles driven beforehand ...
Old Apr 16, 2020 | 10:38 AM
California doesn't hook up to the OBD1 connector. There's no information there that they could access anyway, that they can't get by just looking at the Check Engine light. If the light comes on with the key on & engine off, and goes out when the engine starts, then that's all they check.
They'll check the gas cap on a little vacuum machine, give it a visual, and if it passes the visual, the emissions using a specific driving schedule on the dyno. For the visual, they'll probably have somebody's Emissions Controls catalog and look up your car, and verify that everything the catalog calls for is where it calls for it to be, and that it all appears to be hooked up like it's supposed to be. They may check the ignition timing; if they do that, it'll be part of the visual but before the dyno, and then they HAVE TO disconnect the battery to clear the light afterwards.
No driving at all is necessary after changing the battery. You could even put a new battery in while it's already sitting on the rollers and it would be fine.
Old Apr 17, 2023 | 05:41 PM
Kamerokid's Avatar
Axle/Gears: 700R4
Thanks everybody for all your great answers! I'm glad I don't need to put a ton of miles on it like the newer cars. Thankfully, I haven't failed a smog check in years, and I live in California. One of, if not the worst states in America for smog laws. I only wish they passed a law out here that stated you don't need to smog your car after 30 years. 😎👍
Old Apr 17, 2023 | 09:12 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
That is ridiculous that cali still requires that. Bunch of BS imo.
Old Apr 18, 2023 | 09:11 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Going after the small number of 35+ year-old cars rather than the big industrial polluters seems to me like driving a thumb tack with a sledgehammer.
syc0path
Dec 26, 2019 01:37 PM
86NiteRider
Apr 13, 2005 11:41 PM
KCobain147
Dec 27, 2002 07:37 AM
logikal6785
Aug 23, 2002 11:43 AM
