Cassette player issues
Old May 21, 2020 | 10:03 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Transmission: 4 Speed automatic
When I try to play a cassette on the stockIstock radio only get sound from the passenger speakers. When I set the balance all the way to the left I get no sound. I already played a demagnetizer/head cleaner in it. Any suggestions?
Old May 21, 2020 | 10:05 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Re: Cassette player issues
I should mention that all speakers work when listening to fm/am
Old May 21, 2020 | 10:41 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
If you have verified that all the speakers function from a different source (in your case, the radio), then the problem is in the cassette-electronics portion of the unit. The fix will require removal from the vehicle and component-level electronic troubleshooting, not something usually user serviceable.
You'll need to find a repair shop specializing in such work, something not easy to find these days.
Old May 21, 2020 | 10:57 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
Do you know where I could get another nos or refurbished one, or does anyone make new ones that look like the originals?
Old May 21, 2020 | 11:38 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
If the Google doesn't turn up any leads, your next-best chance of finding something will be on this site.
Old May 22, 2020 | 05:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cassete Bet
An option would be: Transfer the cassets to CD, and replace the AM-FM-Casset player with an AM-FM-CD player.
You'll be better off in the long run due to the fact your songs will not decrease in quality over time.
HappyRacing!
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
Old May 22, 2020 | 05:34 PM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
You're probably right... I just took it in to a shop and we'll see what they can do. I'd rather keep the radio original. I'm not really attracted to any aftermarket stereos that play CD's. They just look too modern and flashy. Just too much going on with them.
Old May 24, 2020 | 10:08 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Send me a PM after you talk to the radio shop. Depending on the radio you have - or the radio you might prefer to have - I might be able to help.
Old Jun 7, 2020 | 07:24 AM
AfdahlBo's Avatar
Car: 1986 FIREBIRD
Engine: 2.8l V6
I just got the radio back and it works again, the guy said that when you switch from fm to cassette it manually flips a switch inside, which had worn out. Thanks for your suggestions
Mick Keinedaten
Car Audio
Aug 16, 2023 01:00 PM
shred5150
Car Audio
Jul 2, 2010 08:40 PM
ken3983
Car Audio
Apr 9, 2008 08:25 AM
JohnS
Car Audio
Mar 4, 2005 06:37 PM
MasterEvilAce
Car Audio
Mar 3, 2004 05:05 PM
