Removed ecm and carb. now no cruise
Old Jun 20, 2020 | 11:18 AM
Ct1987's Avatar
Hi,
I have searched this subject to no end with no answer. I did find a post on a Camaro site that tried to explain it, however the connector they speak of is not in my car, that I can find.
Here is what I did, removed the carb for Holley Sniper system. In doing so, it isolated the ecm. From that point on, I had no Cruise control. Fast forward to actually removing the ecm and all its wiring, I then lost the speedo. The VSS module gets it ground from the connection to the ecm. I re-established a ground on the VSS and the speedo works. There were three cables coming from the ecu. Two main connectors that go the harness to the engine bay and a cable coming from two connectors, where the wires go up up under the dash. One of those connectors had a ground wire that was not grounded. I grounded the VSS ground and plug ground to a chassis bolt.
Still no cruise. Attached photo show the the two items under the passenger side of the car, and how I grounded them. (1987 Formula 305 engine)
I would appreciate any help you can give me. I am sure I am not the only that had this problem.
Thanks....Louis
Old Jun 21, 2020 | 07:40 PM
Ct1987's Avatar
Re: Removed ecm and carb. now no cruise
Anybody??
Louis
Old Jun 21, 2020 | 08:39 PM
GeneralDisorder's Avatar
ECM doesn't control the cruise. The CC module depends on the signal from the yellow buffer box. My CC works with my stand-alone (LINK) and I am using an SGI-5E to control the various vss signals with the yellow buffer box deleted.
GD
Old Jun 22, 2020 | 08:49 AM
Ct1987's Avatar
GD
Hi GD, your link does not work. Thanks for the reply.
Louis
Old Jun 22, 2020 | 12:13 PM
Louis
It's not a hyperlink. I'm running a LINK stand-alone ECU.
GD
Old Jun 22, 2020 | 02:57 PM
Ct1987's Avatar
GD
Hi GD,
Now I know what you are talking about.
thanks,
Louis
90camaro355rs
Apr 28, 2014 08:09 AM
watajob
Apr 2, 2012 03:37 PM
88Formula383
Jun 8, 2009 08:45 PM
PV9685
Oct 1, 2007 07:40 AM
GeeJenn91RSV8
May 16, 2007 07:09 PM
