Trying to track down Code 33 and came across this
Old Aug 1, 2020 | 01:08 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello,
While trying to figure out why my car is running like crap (Code 33) I came across this connector.
It was filled to the brim with some kind of grease, I have no idea how.
I tried to clean it the best I could, here are the before pictures.
Something strange to me was that the female end has three wires, yet the male end only has 2.
Is this related to my issue at all? My code unfortunately didn't go away after cleaning them the best I could. I am getting some contact cleaner tomorrow.
I think my best course of action would be to replace the connector entirely, but I am not certain on how to remove the wires from this connector, or if it's possible. If I could get info on what this connector is for, hopefully I can begin moving forward.
On a side note, where are the most common places for a vacuum leak? I'm thinking that might be playing into this a bit, although I idle fine. After my accident, my cruise control stopped working, so I am thinking that might be part of my problem. All the lines look solid...
Thanks in advance!
Old Aug 1, 2020 | 01:55 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Re: Trying to track down Code 33 and came across this
The same crap was in some of the connectors in my car....maybe it was a dealer service thing back in the days..??
Hawks has several pigtails for sale, I replaced this one, cleared some codes right away!
https://www.hawksmotorsports.com/85-...lay-connector/
Old Aug 1, 2020 | 02:13 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Various times over the past decades. automobile manufacturers, packed electrical connections with grease. Usually in areas prone to moisture. Ford used white lithium grease, which after decades gets hard and difficult to remove. I use dielectric grease wherever moisture might be a concern, with great success.
Old Aug 1, 2020 | 03:00 AM
Annihilate's Avatar
Engine: 5.0
What codes did you have? My fuel pump seems to be seeing pretty consistent voltage.
I didn't really see anything similar to mine on hawks unfortunately. I wonder what it's for and if it's properly hooked up. It's pretty strange to me there are three female prongs and only two male.
Well this is sure a fun fact. Whoopsie daisy on my part for cleaning it out! Guess I should finish the job and use Di Electric instead.
Old Aug 1, 2020 | 04:04 AM
I had intermittent code 34, should not be related to that pigtail, but after replacing it, it ( most times) went away..
I didn't like the look of all that dirty, greasy crap in it..
Hawks has several pigtails on offer, search their website!
Old Aug 1, 2020 | 04:05 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Just make sure the metal contacts are not burned or otherwise damaged.
pvr007
May 11, 2012 09:59 PM
pletch
Apr 25, 2007 09:34 PM
87GTAtrans
Oct 13, 2003 06:37 PM
IROC57TPI
Jun 12, 2002 07:13 AM
aziroc
Mar 15, 2002 01:47 AM
