does not crank ONLY when engine is hot
Old Aug 14, 2020 | 12:07 PM
babadioum's Avatar
Car: 1991 CHEVROLET CAMARO Z28
Engine: 6 LITER after rebuilding :)
Transmission: 700 R4
Axle/Gears: 3.23 / 9:7:1
Odd problem: after driving for, say, 10-20 miles, and during that time, stopping at few places, turning off the engine, starting and driving again for a few times, comes a point when engine does not crank, but after 10-15 minutes of engine cooling off, cranks very strong and starts immediately and strong like there were no problems. The issue and the symptom is ALWAYS the same. Also, before the no crank situation occurs, that is during the last crank before it does not, it almost always hesitates at crank for a second but cranks: It goes "nn nn vrooom (starts)" within a span of a second Next one ends up with no crank which points out to the problem definitely related to hot engine's heat effect at one of those related components, I think.
I know that, technically speaking it resides at one of these: ignition switch, starter solenoid, starter enable relay, automatic transmission switch, pass key module. I hope that the (hot engine/no crank--> cooling for 15-20 min/ perfect crank and start) symptom can point out to the exact component without going through the diagnostic process of checking each one.
Can anyone point out to the faulty component with a fair amount of certainty please? Thank you in advance for your attention and time
Old Aug 14, 2020 | 12:51 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: does not crank ONLY when engine is hot
If you're looking for 'certainty' from electrical system troubleshooting on an internet forum, you're barking up the wrong tree.
I'd suspect the starter is wearing out though.
Old Aug 14, 2020 | 12:58 PM
babadioum's Avatar
starter is brand new but awfully close to double exhaust pipes hence I suspect the heat factor after certain time. I was thinking the same as the most likely component though: perhaps covering it with a heat resistant material around the starter might solve the problem.
Old Aug 14, 2020 | 01:03 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
A new starter is still susceptible to heat-soak. Try fashioning a heat shield from a piece of sheet metal.
Old Aug 14, 2020 | 01:04 PM
babadioum's Avatar
There is one but apparently insufficient.
Old Aug 14, 2020 | 03:51 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Check your timing it may be too far advanced
Old Aug 14, 2020 | 04:31 PM
babadioum's Avatar
6 degrees, rebuilt engine, we have been meticulous about engine details Also, timing would have caused other engine run issues, I believe.
Old Aug 14, 2020 | 05:44 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I had a new engine do the same thing ran perfectly and started when cool but run it for a while park it then it wouldn't crank until it cooled down. Put 2 new starters and a new battery in it until someone suggested i back off the timing. Backed it off 4 degrees and started everytime. Not saying its the issue but its real easy to rule out.
Old Aug 14, 2020 | 07:31 PM
NoEmissions84TA's Avatar
Do you have headers? And what type of starter motor are you using?
Old Aug 15, 2020 | 01:32 AM
babadioum's Avatar
Intriguing, I'll keep that in mind.
Old Aug 15, 2020 | 01:35 AM
babadioum's Avatar
Stock. AC DELCO OEM, stock again.
Old Aug 15, 2020 | 01:38 AM
babadioum's Avatar
How long was "until cooled down" in your experience? Mine is 10-15 min.
Old Aug 15, 2020 | 06:02 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
also are you sure your starter is shimmed correctly and not too tight to the flexplate / flywheel
Old Aug 15, 2020 | 10:00 AM
babadioum's Avatar
yes. also I think that would create problems even when attempting cold start which doesn't at all.
Old Aug 15, 2020 | 02:20 PM
alan91z28's Avatar
COTM Editor
it certainly can. however if it isnt shimmed right without enough gap it can be ok cold and then be a problem hot as the gap gets slightly smaller as everything heats up due to the coef of expansion
Old Aug 15, 2020 | 09:37 PM
babadioum's Avatar
Yes, I agree, but also think that it will also crank very slowly in that case, grinding: this is dead when hot all of a sudden ,n the "next" start attempt and back like no other after 10 min. of cooling.
Old Aug 16, 2020 | 11:57 AM
MrMac98's Avatar
I had a very similar problem. I did the heat shield, multiple starters etc...then i installed the ford solinoid, I rerouted the stock wiring harness(without modification) to the solenoid then i added a Large cable from solenoid
to starter and jumpered the small "start" terminal to the larger terminal at starter.
Now all is good and no issues at anytime with starting..........
Old Aug 16, 2020 | 02:16 PM
babadioum's Avatar
Make sense. I'll go with the least expensive approach first and wrap the whole thing with an aliminum heat cover and fix it in its place with plastic cuffs. If the problem is the heat absorption, there is a very good chance it will solve it.
littlevin91
Oct 10, 2011 11:00 PM
BluFBdy
Apr 25, 2008 03:35 PM
TTA#545
Dec 3, 2007 11:53 PM
'86 350
Sep 7, 2006 08:51 PM
Tx92rs
Jan 11, 2003 07:22 PM
