Digital Dash to Analog
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
If I wanted to get rid of my GTA's digital dash and go analog, would I just need the cluster and bezel? Or do I need an analog harness?
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Digital Dash to Analog
You would need to get the analog connectors for the dash carrier and move all the wiring over to those connectors.
Looks like you live near me, if you're in Hamilton near Trenton
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IMO: Easier to just unbolt the dash housing,..... remove the GTA DD dash harness, & install teh analog harness in it's place.
The Body/Taillight harness ( from about the rear of the drivers door back) might be different too. Well,...... I know it's different, but not sure if the analog version is plug and play. *MIGHT* need to splice a few wires if you swapped to the analog Dash harness.
P.S. I've got an analog dash harness from an 88 Formula.
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
You need to replace just about every harness on the car.
Gosh it's hard for me to understand why anyone would want to swap the digital dash for analog. I know it's a matter of taste, but to my eye, the GTA digital cluster is one of the best looking designs to come from the 1980s. It's visually stunning.
