Fusible Links good but no power for electronics
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So my power locks, mirrors, hatch, and interior lightning do not work. I checked the fuse box with a voltmeter and there is 12V across every fuse dealing with power accessories. I checked the fusible link and they are good. What I did was probe the wires the fusible links are on about 2 feet from the starter and all 3 had power. Only that purple wire on the starter with the fusible links had no power but I believe that is for starting the car.
At this point what else can I check to figure out why half the electronics aren't working?
Note: hatch buttons doesn't release the hatch but it does turn the brake light on, on the dash. I tried it with the e brake and brake pedal pushed in and it still won't release the hatch. The hatch motor is pulled all the way down. It was working when I bought the car and stopped working the moment I pulled it in my driveway lmao
