Rear defrost not working relay?
Old Dec 22, 2020 | 08:46 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
Rear defrost button lights up on dash when pressed and looks like everything is connected at the glass end. Where is the defrost relay at? Thats the only thing I can think of that could be bad. Would the light still light up if the relay was bad?
Old Dec 22, 2020 | 04:16 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Rear defrost not working relay?
Although I don't have the 1988 diagram , I believe this 1992 diagram to be the same . With that said , the light appears to be controlled by the relay's switched contact so if the light is lighting the relay should be ok . Were this mine to diagnose I'd start by turning the defroster on and checking for +12V on the left (driver's) side strut connector . If it's got power there then I'd check the right (passenger's) side strut connector to make sure it's grounded .
Old Dec 22, 2020 | 08:34 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
In addition to what Orangebird said, I have seen where over time the lines get damaged to the point where current can't travel across them and more. Way back in the day I found a kit that was sort of like white out and had a stencil to repair the broken lines.
redwolf7374
Mar 5, 2020 08:46 PM
Galaxie500XL
Feb 18, 2016 01:00 PM
razor
May 10, 2004 10:07 PM
91 Camaro Z28
Mar 27, 2003 03:35 PM
ucbearcat
Feb 11, 2001 05:46 PM
