84 Z28 Signal buzzer wont turn off
Old Dec 30, 2020 | 12:01 AM
Streetglide103's Avatar
Hey everyone I am having an issue with the signal ticker / buzzer. I went to make a right turn yesterday and the noise didnt cancel after my steering wheel came back to center. My signal lights all work correctly but the tick/tock noise when the signal is activated wont turn off, sounds like its coming from the under the steering wheel somewhere. but as soon as I start the vehicle I cannot get the signal sound to turn off. Its on constantly weather I am signaling or not.
Any ideas? On where to start, any help is appreciated thank you! Car is a 1984 Z28
Old Jan 10, 2021 | 10:29 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Re: 84 Z28 Signal buzzer wont turn off
Unfortunately you may need a turn signal switch. While the flasher is under the dash, your cause is most likely the switch itself,which is inside the steering column. You will need to pull the steering wheel and lock plate to be sure and to fix it.
Old Jan 10, 2021 | 10:36 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Unplug it...
lewandom
Oct 1, 2015 08:15 AM
sixty6
Oct 23, 2009 05:45 PM
Rabbitt
Jul 4, 2005 01:58 PM
