Coolant Sender P/N Needed 85-89 Guages
Old Jan 10, 2021 | 08:40 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey All,
I am trying to track down a p/n for a coolant sender for my temp gauge for the 85-89 style gauges.
The parts stores call for a TS76 by Standard. I have tried 2 of the TS76s. The first barely registered a temp ever. The second reads max when the car is ~140. I do have a third, but am hesitant to install it as I doubt it would work, and cannot return it if it's installed.
I have also tried a VDO 323-059, and while it read pretty good for a while, the hotter the engine got, the more off the gauge read, I suspect that is because it is a sender that reads up to 300 F and my gauge stops at 260 F. They do have 250 F variants, but I am not sure if they are worth the try.
My sender port is 3/8 NPT 18.
I have verified the integrity of the gauge.
From my electrical manual, it seems that the resistance should be ~1400 ohms @100 F, and ~55 ohms @260 F.
My original sender that worked has been lost to the engine swap and I have been trying to track down a correct one since.
The original sender had the circular spade-type connector, rather then the standard spade. Either is fine with me, so long as it runs the gauge fine.
Any help would be appreciated as I am tired to guessing and Summit/Jegs have not been able to help. VDO is the most promising supplier, but they do not have a contact number.
SC87'GTA
Jan 18, 2008 05:49 AM
Firebird1984
Apr 15, 2006 10:06 PM
lighthorseozzy1
Sep 17, 2003 05:51 PM
gearhead6127
Aug 29, 2002 09:45 AM
CAMARO82
Jul 3, 2002 11:35 AM
