Key cylinder
Old Jan 30, 2021 | 06:48 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Key cylinder
Do i have to be able to turn the ignition key in order to replace the key cylinder. Cause this won't move
Old Jan 30, 2021 | 07:27 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Key cylinder
No, its held in with a pin.
Lookup any YouTube video on how to replace an ignition cylinder on a GM Passkey (vats) column. 99% of it is the same across the board.
Old Jan 31, 2021 | 10:21 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: Key cylinder
Thanks. It's a 85 s/c. No vats.
Old Jan 31, 2021 | 05:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Key cylinder
On my 92 you have to remove steering wheel and beyond to access the screw/pin that holds it in
Old Jan 31, 2021 | 06:07 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: Key cylinder
I know. but the book says to turn the key to run before it's disassembled. If I can't get the key to turn, I can't put it in run position. Good to know i can still change out the cylinder even if it won't turn. Fixing to be picking up the car next week
2012sergen11
May 22, 2016 11:31 PM
blacksunshine'91
Dec 20, 2012 06:33 PM
weswisehart
Nov 23, 2009 10:07 PM
Slow2.8
Jun 21, 2006 06:17 PM
Riley's35089rs+
Sep 11, 2004 10:35 AM
