91 RS running lights wont turn off even with key off and switch?
Old Feb 25, 2021 | 07:24 PM
88irocz91rally's Avatar
Car: 1988iroc z and 1991 Camaro Rs
Transmission: 4 speed and 5 speex
Ok I could use some help troubleshooting ...my running lights stay on all the time even with lights switch pushed in and key off ? I did research the forums I did find one about possibly a stereo wire brown and yellow mistakingly wired together but I thought that might not be the issue as I installed my console and radio recently but I remembered when I first tried the stereo out didn't have the problem it seemed to pop up after I removed one side of the tail light housing and replace with new bulbs as some were burnt out and broken after the paint job was done , one day I just noticed one of the headlights was on when I connected the battery other side was off because I had the burnt bulbs removed . I just replaced all the bulbs and they all work fine now but like I said they stay on? Sorry if this got very wordy just trying to give the best explanation I can and just trying to get some ideas what to look for thanks!
Old Mar 8, 2021 | 04:10 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
¤¤ Haunted Lights ¤¤
With the headlight switch in the OFF position, use a meter to see if there is power on the brown wire at the switch.
If yes, disconnect that wire.
Now, is there still power on that wire?
Happy Racing!
My Bumper Sticker Says — "If You Can Read This, You're Not Good Enuff To Pass Me"
maromaro
Aug 5, 2020 08:20 PM
Rick1616
Jun 29, 2020 04:53 PM
jackrabbit_slim
Oct 3, 2009 05:05 AM
