Starter wire melting
Old May 2, 2021 | 08:19 PM
Nathan Ouradnik's Avatar
Car: 1987 camaro Sport coupe
Engine: 2.8l multiport FI
Transmission: 4 speed with OD
There is a red and black wires running to a fusible link and only one wire coming out of the link. It says fusible 16ga. The cable has been spliced multiple times by previous owners. Every time I connect that wire to the big positive post of the starter, it's fine. But when I connect the battery, that wire melts, quite instantly. I need help, my car doesnt work without that wire
Old May 2, 2021 | 08:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Starter wire melting
Find the short to ground !
Old May 2, 2021 | 08:44 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Would it be unusual to have both a red and a black wire going to the fusible link?
Old May 2, 2021 | 09:29 PM
Engine: Lb9
Transmission: M20
It’s been spliced who knows could be a black fusible link.
Old May 2, 2021 | 09:44 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Other than battery cables, black wires usually go to ground. Try it without the black wire on the starter. There SHOULD be 2 red wires going to the positive stud on the starter along with the positive battery cable...
Old May 3, 2021 | 12:52 PM
okay so was remembering incorrectly, it is actually two red wires into one the others work fine. as you can see this wire has been spliced by a previous owner. everything past the rubber "fusible 16ga" tag is melting off
Old May 3, 2021 | 01:00 PM
where would this wire happen to come from?
Old May 3, 2021 | 01:02 PM
Engine: Lb9
Transmission: M20
Fuse box ,that’s the link connection
Old May 3, 2021 | 01:12 PM
the fusebox under the dash? if so why dont wiring diagrams show that the starter connects to the fusebox?
Old May 3, 2021 | 01:14 PM
Engine: Lb9
Transmission: M20
To c100 to fuse box look at power distribution
Old May 3, 2021 | 01:16 PM
im sorry what are you saying. this is my first time doing wiring
Old May 3, 2021 | 01:24 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It does show that, essentially, if you understand how to read the service manual. It's in the power distribution section
Old May 3, 2021 | 01:27 PM
Where would the c100 be located under my dash
Old May 3, 2021 | 01:29 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
If a fusible link melts, that means there is a HIGH amperage draw, this is usually a direct short to ground. There is really no way for us to help you with that.
You can try replacing the link, pull ALL the fuses in the fuse box and re-connect to the starter. If it still blows that means you have a short to ground somewhere in the circuit leading to the fuse box, or possibly the headlight, starter crank or ignition circuits since those circuits do not have fuses and are only protected by the link.
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
C100 is at the firewall on the LH side next to the brake booster
Old May 3, 2021 | 01:50 PM
So what seeing is that my best option is to track every inch of that wire throughout the engine bay for a cut in the wire. And if that doesnt work , look at the fuse panel?
Old May 4, 2021 | 12:40 PM
OrangeBird's Avatar
Car: 1989 Firebird
Please don't take this as an insult, because it's not, , , , You are, training wise, about as qualified to repair this as you are to be doing brain surgery. You say this is your first time doing wiring, well, it takes quite a while to learn the skills needed to troubleshoot a problem like this and I honestly think you may be better off finding an honest person who knows automotive electrical and paying to have it fixed . There are so many pitfalls that you could encounter taking stuff apart looking for a short that may not even be visually obvious to a trained eye that no one can produce an easy list for someone whose never dealt with car wiring.
Like I said, I'm not trying to be a dick or diss you for what you don't know, I just think you may do better farming this job out VS taking stuff apart yourself......
Old May 4, 2021 | 07:49 PM
Engine: Lb9
Transmission: M20
You could isolate the circuit and disconnect c100 ohm the shorted wire to ground . If open the issue is on the other side of the bulkhead.
Nik Smith
Sep 14, 2016 04:43 PM
Project 3.4 Camaro
Sep 9, 2010 11:22 PM
_87TA_
Jul 28, 2010 02:03 PM
firebirdta84
May 27, 2007 02:48 PM
