MAF Proper Idle Readout
Old Jul 17, 2021 | 07:47 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello everyone, just a quick question.
My MAF seems to idle at about 9 g/s is this normal? Or is this indictive of a small vacuum leak somewhere?
I'm chasing some codes around right now, and I am in the process of installing a new pigtail for the MAF as the clip on the stock one broke before I had the car.
It is a new MAF, and I didn't cheap out on it, but I didn't spend $300 either. I believe I bought this one. DELPHI AF10320
I'm really not looking to buy another MAF, I hope the pigtail is the cause of the code, or maybe a vacuum leak. I'm gonna try the cigar test on Monday.
Old Jul 17, 2021 | 10:16 PM
Annihilate's Avatar
Engine: 5.0
Re: MAF Proper Idle Readout
Also, the PO put a 58mm BBK TB on the car. Would this cause any major issues?
I believe it is stock outside of that, but can't be certain on the internals.
48,000 Miles is on odometer, it really shouldn't be giving me this much trouble lol.
Old Jul 17, 2021 | 11:07 PM
vorteciroc's Avatar
Top Answer: 1
With a "Bone-Stock" TPI Engine...
I would normally see 6 to 8 grams per second at an idle.
Unless you have significantly increased the air-flow at an idle (unlikely), then you should be just fine.
Old Jul 18, 2021 | 02:46 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
My '89 reads about 8.5 g/s +/- 0.5, but it also idles up a little when I connect the datalogger.
Old Jul 18, 2021 | 07:42 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
GM spec according to the 88 FSM is 4-7 at idle with the engine warm, I’ve seen the Delphi MAF readings are a little higher than Bosch , like the 9 that was reported. If your BLMs and other data are in line I wouldn’t worry about it much. My modified L98 reads 5 with engine warmed up and at idle.
Also I would go back to stock on the throttle body, that 58mm is too much on a stock engine. It can hurt performance more than help it and could also have a leak, I’ve seen a few posts about BBKs having issues like that.
1701-Z
May 31, 2016 09:32 PM
bdiroc
Sep 29, 2010 05:44 AM
2kickassbirds
Apr 12, 2008 05:45 PM
Test King
Jul 18, 2002 02:31 PM
Matt87GTA
Jun 13, 2002 06:09 PM
