12 volt keyed power connection
Old Aug 18, 2021 | 07:49 AM
cjpenny89's Avatar
I am looking for a good reliable easy to get at keyed 12v power source for my Holley Sniper EFI. Is there any keyed power sources in the engine compartment? I can get a wire to the fuse box is there a good keyed source there?
Thoughts
Old Aug 18, 2021 | 08:55 AM
cjpenny89's Avatar
Re: 12 volt keyed power connection
I have researched enough and found my answer I will hook up to the fuse block on acc with a spade connector.
Old Aug 18, 2021 | 10:32 AM
skinny z's Avatar
There are also plug in connectors by Pico that are designed to fit into the various types of keyed slots in the fuse block.
955-BP and 958-BP.
Better than a spade terminal which have a tendency to fall out at the most inopportune time.
Old Aug 18, 2021 | 10:36 AM
cjpenny89's Avatar
thank you I will look into some of these
Old Aug 18, 2021 | 10:41 AM
cjpenny89's Avatar
what website did you find this on? I can not seem to locate them
Amazon uses part numbers listed below
Pico 0951pt Gm Fuse Tap Batt Cavity(Blk)
Pico 0952pt Gm Fuse Tap Ign Cavity(Clear)
Old Aug 18, 2021 | 12:22 PM
skinny z's Avatar
I found those in the Pico catalogue.
They were in stock at my local auto parts store.
Doing a quick search and by your description above, I'd say those will also work.
kitt23
Car Audio
May 8, 2013 11:52 PM
gmstrong
Car Audio
Mar 28, 2011 06:47 AM
Titan85
Oct 9, 2007 06:00 AM
1987earthquake
Jul 26, 2007 10:52 AM
jslick89
Mar 19, 2006 11:02 PM
