1992 Camaro 5.7 Automatic...Speed Sensor?
Old Aug 22, 2021 | 11:28 AM
dale3in98's Avatar
Hi,
I wasn't sure where to place this question...thought I would start here. Over winter storage, my speedometer, odometer and trip odometer stopped working. I read numerous posts and some point to the transmission speed sensor as the issue if speedometer and odometer don't work.
My questions are...does the 92 automatic have a speed sensor? If so, do you have a part number or location to purchase one? If one exists, where is it located?
TIA...Mike
Old Aug 22, 2021 | 02:59 PM
vorteciroc's Avatar
Top Answer: 1
Re: 1992 Camaro 5.7 Automatic...Speed Sensor?
Yes the 1992 Camaros with L98 Engine used a VSS...
However, they used a VSS that was driven by Cable-Speedometer Gears.
GM/ ACDelco does not produce one anymore.
Here is a part number for Standard Motor products: SC12.
Try RockAuto.com
Old Aug 22, 2021 | 03:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
ACDelco 213-198 if you need I have a new one gm 10456089. Located on the transmission tail housing.
Old Aug 22, 2021 | 03:44 PM
vorteciroc's Avatar
Top Answer: 1
NOS?
Old Aug 22, 2021 | 04:04 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
If vorteciroc does not take it, I am interested.
Old Aug 22, 2021 | 04:16 PM
Engine: Lb9
Transmission: M20
bummer , it’s not new have a like new 10456088 gm depending on gear ratio
you can drive and test acv at ecm b9 and b10 purple and yellow wires.
Old Aug 22, 2021 | 05:37 PM
dale3in98's Avatar
Try RockAuto.com
Thanks for the info...got one on the way.
Old Aug 26, 2021 | 09:37 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
However, they used a VSS that was driven by Cable-Speedometer Gears.............
For future ref: Electric speedo gears and Cable speedo gears are not compatible. All speedo DRIVE speedo gears ( tranny shaft mounted ) are the same, but the DRIVEN speedo gears ( sending unit mounted ) are specific. Electric speedo gears are "flat" at the sending unit mounting surface; cable DRIVEN speedo gears have a "post" on the sending unit mounting surface.
Fairly certain this is true for the 84-89 electric VSS DRIVEN gears ( Berlinetta, Corvette, Firebird ) as well as the 90-92 VSS DRIVEN gears ( F-Body ) when compared to Third Gen cable sending unit speedo gears.
Old Aug 26, 2021 | 09:41 PM
vorteciroc's Avatar
Top Answer: 1
Indeed.
Thank you for Posting this, as I did not think of it at the time.
Beringerrph
Jul 27, 2019 08:40 AM
Camaro <Mustang
Jul 6, 2008 02:37 AM
Scamo-2.8
Apr 6, 2005 11:33 AM
redbird6815
Mar 13, 2003 06:51 PM
