Battery Cable Routing
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Looking for battery cable routing for a TPI Firebird which has the battery on the driver side, my 91’ Firebird originally came 305 TBI which had the battery on the passenger side. I’m going to make my own battery cables and could use some inspiration with the factory routing so pictures would be very helpful.
Engine: 4++,350 & 305 CIs
Re: Battery Cable Routing
Starter over the motor mount,
through the clamp on the block
to the 2 clamps on the pass frame rail
down to clips under the dual fans
up to the clip on the steering box lines.
then to battery
then to battery
Engine: 5.7 HSR
JPrevost
Aug 31, 2004 12:22 AM
