wiring harness for dash and interior
Old Sep 9, 2021 | 11:00 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
does anyone make a new wiring harness that replaces the one under the dash and inside the car? painless has them for the tpi motor only.
any suggestions on how to get new wiring for the dash stuff, gauge cluster, switches, etc
thanks
Old Sep 15, 2021 | 09:50 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Re: wiring harness for dash and interior
anywhere to send old one to get fixed?
Old Sep 16, 2021 | 01:26 AM
vorteciroc's Avatar
Top Answer: 1
There are a few guys here that sell used Harnesses for the Passenger-Compartment, including the Dash-Board Harness.
I do not believe anyone builds new ones... many of the Electrical-Connectors have been too difficult to find new.
Old Sep 16, 2021 | 07:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you need a replacement harness just find a god used one If you are goin to go custom, pull it out and pin it the way you need. It takes time but you will learn a lot about your car when tracing through the body harness circuits.
Old Sep 21, 2021 | 10:03 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You will have to get a used one from the same year and model car, or you might be making changes to get everything to work afterwards
Old Sep 21, 2021 | 10:33 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
thnx
Veaceonee
Aug 18, 2014 11:00 AM
AtreyuBigBlock
Mar 21, 2012 09:22 PM
941camarokid
Feb 17, 2012 02:43 PM
mos68x
Feb 1, 2010 03:13 PM
