Window power wire gets really hot and smokes
Old Feb 7, 2022 | 05:55 PM
Soupyman's Avatar
I checked ground and it was fine, the power may be a problem as I don't have a specific fuse I plug into because so far all of them haven't worked even the circuit breakers. The wire seems to be a good gauge but then again Im not really sure.
When i fixed the splice mid wire it stopped smoking there and moved to the switch. Earlier I got the windows to move, this Is a universal harness on a car not meant to have power windows, and they never did before. Once they moved the wires got very hot and I shut the car off.
What could be the cause of this
Old Feb 7, 2022 | 05:58 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Window power wire gets really hot and smokes
Bad ground somewhere
Old Feb 7, 2022 | 06:20 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by Soupyman
I checked ground and it was fine......What could be the cause of this
Yep, not likely the ground . If you have a properly sized circuit breaker in there (pretty sure the window circuit uses a 30A breaker) , and your using an aftermarket "universal" harness, and the window motors will in fact move while the wire is roasting , , , , , then the wire is too small to supply enough current to the window motor
Old Feb 7, 2022 | 06:43 PM
Soupyman's Avatar
Im actually thinking of changing ground and cleaning the surface for it just to be safe
Old Feb 7, 2022 | 06:46 PM
Soupyman's Avatar
ok thank you, like i said I plan to move ground to its proper location and clean it up as every ground is a bit rusted but i do have an old wiring harness the previous owner gave me that I didn't trust entirely so I can use the wire from that
Soupyman
Feb 4, 2022 09:14 PM
1 DwnCam
Dec 17, 2008 07:31 PM
OS3Fleming
Jul 20, 2007 08:14 PM
BOTTLEDZ28
Sep 10, 2005 07:27 PM
F-Bobby
Sep 16, 2004 08:10 AM
